Oil Bath to Air Filter
Nanook
I've recently purchased a 1963 c1100 (two wheel drive) pickup. It has a 304 motor with a manual transmission and a two barrel holly with an oil bath air cleaner. I'd like to get rid of the oil bath and replace with pan filter. Does anyone know where I can find a pan to fit this carburetor so that I can use the basic air filter. By the way, I'm new to this and in no consider myself a motorhead. I'm having fun refurbishing this gem.
The first step is to make positive id of your carb. Wag is that it is an early 2300 model. If you need help identifying, simply post a pic. The 2300 models require a canister with a 5 and 1/8th inch diameter opening, which is by far the most common air filter dimension. If this is what you have, then the sky is pretty much the limit depending upon your under hood clearance.
