should we do something to absolutely confirm I have the wrong ring? The tach reading from the msd seems pretty conclusive, but I don't want to waste time or money here. Can a paperclip or something be used to feel if each one is a real magnet?
Also, could you please explain what you mean about putting the distributor in the wrong position? Do you mean the rotor can only go in one specific way (not one tooth off either way)? If so, how do I find that position?
If we should take this off the forum, that's fine, you have my e-mail. Thanks.
Added: I got a paperclip and it sticks to every magnet. I assume the 4-cyl ring should only stick to every other one, right?
As you know we stand behind the work we do here at ihon 100%, if something is not right we're going to take care of it. That dam pertronix is not right...so you will receive another distributor that will have the correct parts, and it will be equivalent (or better) than the one I just completed for you. You saw the same level of customer service regarding your carburetor, and the clutch throwout fork which was damaged in use and not due to faulty workmanship, we replaced it anyway.
I have just learned tonite of one more I-4 delco with a pertronix conversion that has this same condition (also running a msd six box). I will get to the bottom of this, I'm already on the shit list at pertronix so this will simply add fuel to the fire.
I certainly realize that this is a pita for you as our customer and I regret this has happened. From our end, it also has a financial impact as we have to deal with this stuff without reimbursement from pertronix or the wholesaler for these items when they are faulty other than a "replacement" part. That's the way it is in this cottage industry, it's all part of customer service.
That delco distributor was never designed to be used in any other engine other than a v8 or four cylinder chevrolet and some other GM family bop (buick/olds/pontiac) motors. It certainly was never intended to be used in the ihc-produced engines and therefore the "window" in the cap for accessing dwell adjustment is not in the optimum location, neither is the lubrication cup and the vacuum advance can. When the same unit is used in the chev/bop applications, that is a non-issue.
In order for the vacuum advance to be located in the correct position to allow distributor rotation for timing adjustment purposes, that compromises the location of the window for dwell adjustment for the I-4 application. Therefore the distributor will only correctly mount in the hole in one particular position which provides about 20* of rotation. That means you have only four exact points of drive gear alignment that phases the rotor in a correct position for a secondary terminal in the cap and to designate that terminal as #1 in the firing order. Any of those four points could be designated #1 if the crankshaft is in the tdc position for #1 cylinder on the compression stroke.
This cannot be achieved by relocating the cap as it's keyed to the distributor body in one distinct location and the two spring-loaded cap hold downs must be properly engaged also.
So stabbing this distributor in an I-4 is no different than stabbing a distributor in any spark-ignition engine. You can stick it in one, two, three, four teeth retarded or advanced...motor won't run. A sv engine will run if the distributor is one tooth retarded or advanced, and I-4 will not! The delco mounting in an sv engine allows enough room to twist the distributor way out of phase in order to fudge the timing so it will run. If not stabbed correctly. The same mounting in an I-4 will not allow enough rotation to allow the engine to at least start.
Stabbing distributors is real simple, but can be tedious on occasion. And there is never any reason to deviate form the same position the distributor was mounted in at the factory.
