Hello guys I'd like to order the nv4500 adapter kit but before I do I have a few questions as I need to figure out what transmission I can use.
-I have a Jeep Dana 300 to put behind the nv4500 and I don't want to buy an adapter for the transfer case. So?
-it is recommended to use the dodge gas or diesel trans. From 1995 or later, will these bolt up directly to my Jeep Dana 300?
-basically from what I have read the trans needs to have a 23 spline output shaft to work with my Jeep Dana 300 and be made in 1995 or later? Is there anything else to look for or do I just need to find one with 23 spline count?
-that being said will the GM 1995 and later nv4500 bolt up to my Jeep Dana 300 without an adapter?
-if not which other years or models gas vs. Diesel should I look for that will work with my Jeep t-case?
Thanks for your time,
brandon a.
brandon a.
