Rusty Scout
NP205 speedo fail and the case seems mounted weird on my 75 pickall???
Well I double checked all cables and speedo corrector and they seem to function fine. Speedo needle comes to life when speedo corrector(adapter) is driven with a drill motor(slowly in reverse).
So no speedo signal out of the NP205. Is this a common problem? I am hoping that whatever needs fixin can be fixed without removing this heavy case.
Also this case seems to hang way below the frame (about 6 inches) and seems to be hanging from only 2 bolts on the passenger side of the tcase crossmember. Is this normal? Seems like a poor design if it is normal. Needs a strut or something to keep it stable I would think?
