tee jay
Need help with no spark issue.
79 Scout II, 345, Holley dist w/points
pulled Scout in garage was idleing then died.
No spark,
dist cap cracked, new cap ,no spark
change points, 0.16 gap, and condensor, no spark
change coil,no spark
changed resistor, no spark
12 volts at + side of coil
12 volts at - side of coil but ,test light does not pulse when cranking engine.
I guess the distributor is turning because everytime I crank it its in a different position.
Change coil wire, no spark
am I missing something here?
No spark,
