I did a quick look and didn't see anyone else with this problem, so it's probably something easy.
I've been tidying up my engine compartment, getting rid of loose wires, putting loom on them, etc....while I was at it I relocated my starter solinoid higher up on the fender near my washer fluid tank. Now, I have no elec, anywhere. No headlights, radio, nothing.
This happened once before and I wiggled the solinoid and it all came back. It was held on by one screw, which was part of my reason for moving it. It's now bolted down solid with 2 nuts/bolts. The wire from the battery is hot, but no power to anything else, and it won't turn over. The hot wire is on the same terminal that the wire from the battery is on, so it should have juice.
It there a circuit breaker somewhere, or a ground point I May be overlooking? Ever heard of this before? Why did wiggling the solinoid fix it before but not now? Are there really gremlins that live in electrical systems?
Thanks in advance for any input....
