Stumblefoot
Its been alot of year since I owned an IH, kinda forgot how different they are.  Just got it off the trailer yesterday, trying to figure out what I have gotten myself into. Its a 6 cyl 4 speed, been off the road since 2014, Put a 4.5 PSI fuel pump on it & got it running, lots of fuel leaks
 has the 1904 carb with glass fuel bowl,it leaks. Valve cover leaks, as does the plate on the side of the engine. somewhere in the past the windows were removed, so floorboards are rusted out and seat is rotten. What other vehicles use the same hardware for the windows and door latch? Not having much luck finding any parts for it. The body is straight frame looks good. clutch works (sort of) brakes are weak but they slow it down some. Those things I can fix. Dont have pics yet, its been wet & nasty. Also, has split ring rims! Those have got to go!  No tire shops will not even touch them. I'll put more info on here as I learn... TX title has no model # or GVW but I think its all on the sticker on the door.
