Zeronomous
Hello all^^, just became part of the International Scout club
, found a old early 70's (I believe) with the 345 engine down toward the gulf coast and picked it up. It was in pretty rough shape, but for the price I couldn't argue, and I have heard nothing but good thing's about scouts. It is the Scout II, I know for sure. We trailered it home, and it actually cranked and ran (albeit rough), long enough to limp it from the car hauler to the driveway. The next day, I took a good look at it and tried to get an idea of where to start. I fired it up, and it ran again just fine, with only a minor water leak out of a front metal hose (right next/under the distributor cap on the passenger side front engine. I began to perform regular maintanence on it, and here's a quick list of what I have done to it over the past couple of day's.
Oil change + filter
rear/front differential fluid change
rubberized the bottom side to seal from more rust forming
lifted the shakles another 2in on the lift.
Replaced the spark plugs
installed window (not fold down), and driver side/passenger side door.
Installed a rear roll bar for future canopy roof
and a few other odds and ends.
To my surprise today, it won't crank
. I first checked the fuel pressure getting to the engine, and it seemed fine enough to crank. I cleaned the little rubbish plastic fuel filter and it filled fine with gasoline on the next attempted crank. I inspected the carb, and jet's were pumping just fine, however no amount of starter fluid could get it to crank. And gas seemed to be getting to the engine fine. I am a bit worried the problem is firing, although I can't seem to narrow it down. I did notice the distributor cap actually rotates on this engine (whole assembly), and wondered if perhaps I bumped it and would that be the cause of it not cranking. New spark plugs, so I don't believe that's the case. Of the actual ignition, this is what I have worked on so far :
inspected and moved the ground on the battery, it was pretty bad, cleaned it up and mounted it on the block near the exhaust manifold.
Checked battery, was ok.
Installed new plugs, although not new wires.
Inspected fuel filter and cleaned it, but it did seem clogged somewhat anyway. Seemed to suck fuel and fill afterward just fine.
I really can't for the life of me figure out what could have happened between it driving just yesterday, and today not firing up, but again I am very new to Scout's, and hopefully someone here knows a good bit about this and can lend a quick tip or 6
. Glad to be here, and thanks!
Oil change + filter
