New Project: '64 C900 step side riding on a '06 Trailblazer
FDChappie
Well-known member
After a long search, I finally found a suitable C900 for this project. I pick it up next week. Purchased a totaled 2006 Trailblazer with the Vortec 4200 I6 and 4x4. I was high bid on a Copart auction @ $625 and by the time it's delivered the cost was $2200. But it only has 114k miles and black leather power seats so it should provide most of what's needed for the conversion. The goal is a practical daily driver. Pictures coming.
Look what followed me home yesterday.
The biggest issue is a rusted cowl. Anyone seen a good resto this. It has almost 100k so unless the engine was rebuilt, I'm sure it is tired.
It is going to ride on this
The TB runs great and has no check engine lights, so I'm not dealing with someone else'es problems. If anyone knows about custom programming BCM's (body control modules) I'm all ears.
Had some time the other day and got the 152 running.
But first I had to make it a roller, finding 15" tires is not easy these days. I ended up with used trailer tires in 225/75-15. Installed 6he tired with my new manual tire machine. It works good.
No big surprises getting the engine running a little oil in each spark plug hole and some 2 cycle fuel down the carb and she fired right off. At first it was running on 3 and popping out the carb. A shot of Marvel Mystery oil in the nurse tank and it cleaned right up. Looks like the head was rebuilt jn the not to distant past as I'm seeing fresh red paint. No smoke either.
I am surprised to find 3.73 gears in the d44, bet it was a dog in the hills. Couldn't get it moving as both the brake and clutch pedals are locked up solid. I'll be looking to sell the chassis and running gear soon if anyone is interested.
Probably has a E67 ecm. You'll have to unlock the ECM and disable VATS and then your BCM's won't affect the engine running.
VATS is just the security system. Once you disable it, the ECM doesn't care. Then all you need to do is scale the MAF. Or you can just drive it as is for a while. You need to find a tuner geeker to do the modifications.
Thanks, you've confirmed other sources of info. Since I'm a life long geeky programmer (just not automotive) I'd like to do much of this myself. The intent is to use the auto headlights, wipers and climate control. Can you recommend a good bi-directional scan tool?
Making some slow progress. Got both trucks running and they both run good. Almost ready to pull the cab on the c900. Any advise on the best way to remove the steering column?
Just got the steering column out. For others in the future, remove the steering wheel, remove clamp under dash. Then loosen clamp where tube meets steering box. Remove steering box and pull shaft out of column. Slide column into cab and up towards rear window. Didn't look like it would fit but it does.
Now onto removing the body mounts.
Making slow progress, body is now off the Trailblazer. Figuring out how the 20 different electrical come apart took a huge amount of time. I also did a lot of extra work because I didn't know the electrical harnesses could be disconnected under the fuse block.
One minor success is that everything came apart with no damage except for the daylight sensor on the dash.
Was laid up for a while due to my back going out, but the cab and front clip are now mounted to the Trailblazer frame. No snarky comments about the welding, they are just heavy tack welds for now.
Rust
For the front body mounts the stock IH mounts are welded to a piece of 1/4" plate welded to the frame.
Tread Synthetic rubber Rust
The rear cab mounts were a little tricky due to the brake lines, wiring and gas tank being in the top and inside of the frame rail. So up and over it is.
Fender Tread Synthetic rubber
IH uses one bolt front and center on the clip. The new cross member is 4" channel iron welded to the front of the frame rails.
Automotive Exterior Bumper Fender Hardtop Pickup truck
Land vehicle Vehicle Tire Wheel Car
The bed is mounted (with 2 bolts anyway). The match up where the bed skirt and receiver hitch are is sweet.
As you'll notice, there's about a 7" gap between the body and bed.
The plan was to extend the bed or get a longer one.
However I tried fitting the seats into the cab and there's not enough room and the bump where the shoulder belt is doesn't help. So now the plan is to extend the cab.
Here's the big picture on how it's coming together.
