The new motor is actually a rebuild that had not been installed, it sat on a pallet for 12 years. The engine has about 15 hours on it since install.
I have a knock that sounds like it is from the #1 cylinder. It is faint when the engine is cold and gets louder when it warms up. After installing cut out valve covers I noticed there are alot of lifters that are not rotating. The #1 cylinder in particular is the noisiest. When I lightly press a hammer handle on the pushrod end of the intake rocker it knocks like crazy. I installed a new lifter and it still knocks. I removed the intake lifter and pushrod to see if it would make a difference and the knocking went away.
Oil pressure on start up is 50 psi, when hot it is 10psi. Vacuum gauge shows 18", the needle is steady. Compression is 135# on all cylinders. There is only a puff of smoke on start up, none when idling or when revving the engine. The motor runs great, plenty of power, steady idle.
Does it sound like a bad cam, cracked piston, weak valve spring?
I am open to all ideas.
