Hello all, this is my first post on here but I have probably read just about every post on here.
I have a 73 Scout II that I will be putting stock Chevy 3/4 ton axles and springs under. I originally intended to put Scout springs and axles back onto it, but later decided to go Chevy. I broke rule #2 (planning) and didnt get axle centerline measurements
my question is, is it possible for anyone with this setup to tell me the measurements for the front and rear spring hangers as well as shackle holes through the frame. I am looking at doing the same setup as the ld Scout buildup, with the shackle reversal kit and dogleg shackles. Or it May be easier to get centerline measurements. Either is fine.
Sorry for the long post. Thanks jph
I just realized this should be in the 4x4 tech segment, sorry
