ok, he wants 200 for the t-case, tranny, driveline and gearbox. I don't think he'd like to separate it.
if any of this stuff can be loaded "easily" in our travel trailer. I'll hook up with ben on the trip down to the IHSFR (we should pass through k-falls on oct. 1). We'll be in the t'all and windshields, fenders, and hoods are out of the question!
Actually Jeff (and ben) I'll "split" the tranny package with ya and I'll keep the t90 and d18, I can use the d18 for a builder and have that ready to go behind the t-34 for kathy's s80 that will be finished this winter! So maybe ben could go ahead and remove the pto as I won't have tools with me for that.
That pto is treasure I sure hate to see get away!
The tranny I'll refurbish and it can be used in someone else's restoration project,...and it can be mated with either a twin stick d20 for a Scout 800 I already have or another d18.
Erik....I also need the same piece of sill that you want! In fact...many folks across the country need that same piece for their t'alls produced as a repair/patch panel. Hopefully the light line dude-in-charge will be at the rallye again this year and we'll lean on him heavily to repop that part if he has the die set!
what I have is a t18 four speed with a twin-stick d20 transfer case from a four cylinder Scout 800 I'm using. This is the setup used with the lay-down version of the 152/196, not the upright version used inna Scout II. The d20 will be removed and a d18 transfer case used instead.
