Thanks Robert!
So I'll take the cap off the #8 rod and crank the motor over by hand to pull the crank away from the rod? Will I need to persuade anything to come off? Once the cap is off and the rod is off the crank, how easy should the bearings come off or do I leave them on?
I'll snap some pix and post next week.
What exactly should I be looking for?
When the cap goes back on, is there any orientation of the bearing on the crank?
Do you think the piston will want to fall out the block?
Now, I'm being lazy, what is the torque spec for putting the cap back on?
