Jeffsarasota
Thank you to everyone so far who is help me with my threads. I'm resurrecting a 78 Scout two. 345 v8 auto trans got it running this weekend pretty well set timing adjust carburetor got rid of vacuum leaks etc. When I started it yesterday I started to hear a loud clicking/ticking/chirp from top passenger side of engine obvious choice was a lifter but it's very loud for a lifter. Today I double checked everything try to reduce the timing a little bit nothing seem to help. Used a stethoscope and listen to different points on the engine and that did not pick it up either.... It is intermittent when the car is a neutral and at idle. It starts up when in gear and a load put on the engine. It does it as engine revs up under load just like a lifter would. Any suggestions are helpful
