Booyah the monkey
Okay, all my lights were working fine except the license plate light so I took one off from a parts Scout and was wiring it but didn't get any light. So I switched the bulbs and nothing, so I decided to switch the wires (stupid) and when I did I lost all the side marker lights and the taillights. However the light lights work when I hit the brakes but not when I pull the light switch. So I disconnected the license plate light altogether. There are no melted wires and there was no smoking. So I checked behind the pull switch to turn on the lights where the wire harness connects to the light switch and everything is connected fine. I also checked under the rear where the taillights and side marker lights connect and all the connections are fine. The panel lights work fine and so do the brake lights in rear and from what I understand they are pretty closely connected to the side marker lights. I am stumped and don't know what to check next. Any help is greatly appreciated. Also, I took a look at the electrical setup in the manual but I don't understand it.
- okay, I am making a little progress. I found out that when I hit the brakes that not only do the tail lights turn on but so do the side marker lights. I have no idea how this happened because prior to messing around with the license plate light everything was working fine. When I incorrectly connected the license plate wires I watched the tail lights go out.
