looking for some help
76ihpickup
Hi my name is lee new to site I have a 76 rally pick up cant find any thing on this year for pickup title has Scout on it and favors one alot but have found some parts dont fit wondering if any one has any scouts this year and what makes them so differnt mostly I have body work to do and want to keep as origianl as I can has all orgianl motor never rebuilt and inter only work really had to be done was starter revers ban in trans thank u for your help
Welcome to the site:
there are variations of Scout iis --
one has a full top with a small rear seat (2 people).
One has a half top (and a bulkhead behind the front seats) with open bed and is referred to as a terra (do not know how it is titled).
In 1976, there was also a traveler -- slightly longer wheelbase (118", I think).
Over the years, the tops could have been swapped around between vehicles -- based on the desires of the current owner.
If you post some pictures, someone more knowledgeable on Scout iis than me can provide better info.
This should probably be moved to basic tech. To clarify what Robert said, beginning with m/y 1976, International offered two longer wheelbase variations along with the standard 100" wb Scout II. This was a stop gap measure by IH after they had ceased production of their full size pickups and travelalls in 1975. One variation being a Scout terra with a fiberglass cab top, steel bulkhead, open bed, and door window glass with one rounded corner. The other variation is the traveler which is the same 118" wb as the terra, but has a backseat, no bulkhead, and a full length fiberglass top with one piece rear lift hatch supported by gas struts. The standard Scout II came with square-cornered door windows and either a full length metal top or a metal cab top and bulkhead. Other than wheelbase, overall body length, installed tops, and door window glass...standard Scout II's, Scout terra pickups, and Scout travelers are basically the same animal with a great many parts in common.
