Robert Kenney
Super Moderator
Well I take some of what a I wrote back. Looks like the base circle varies. That would not be attributed to wear but to being reground. The lobe lift values you gave us are basicly 2 values .224 and .254. Good from a wear indication standpoint. The taper is evident on the heal of the lobes and the lifters were rotating. I hope you maintained the order in which you removed them as they must be retuned to the exact same lobe they were running on or you risk eating the cam. If not new lifters should be installed.
My opinion is to replace the cam in either case. Just not enough money to go through the teardown again.
Robert
Robert
