71 Scout II
345 auto
I recently acquired a 71 Scout II that hasn't been inspected since 06. To my surprise the lights/blinkers all worked. My ocd kicked in when the passenger side blinker indicator wasn't working. As I started jacking with the speedo dash pod things started to get weird. First the blinker stopped working. I replaced as many bulb holders on the back side of the pod as I could and got them working again. Next thing I know the brake lights stopped working. I replaced the brake pedal switch and got them going again. Then I noticed the dimmer switch was shot so I replaced it... All good on the dimmer switch... Now the headlights will come on but the tail lights/license plate light wont (which all worked before I started cooning around in the dash). I re grounded the harness at the back of the vehicle, repaired 1 splice and inspected the harness which all looked good. My question is, do the indicator bulb holders behind the gauges have any impact on the overall circuit, or did I inadvertently pull some wires loose under the dash? Seems like all the issues started when I pulled the bulb holders out. Thanks for the help.
T
345 auto
T
