I have a 73 Scout II 304/auto/4x4. I replaced all the lifters on the pass side of the motor and instead of one noisy worn out one they all make noise. Im not sure what I did wrong. I soaked them in oil, primed them, lubed them, and set them in right. None of of pushrods are bent. Even after priming them, the new lifters were easier to compress by alot. The old set barely moved. What is the proper torque for the rocker shaft bolts. I only let it run for a little more than 10 min before the clattering scared me to turn it off and I havent fired it up since. Help? Oh, I made sure all the bolts and pushrods went back in the same places.
