I have a 75, 304 that sat for a while and I didnt know about the break in for sitting motors. I did use marvel and hand crank the engine about 500 revolutions slowly before cranking.
The motor runs and seemed to be fine but had a tick and a slight "offness" about it. Pull the valve cover and there was #6 intake pr bent. I then proceeded to check all the valve stems to make sure they were freely moving on their own weight, #6 was sticky but I got it clean using the technques in the sticky so the upper end seems ok.
That being said the #6 lifter plunger has no give, it seems stuck. Is this normal. I havent pulled the others yet to check them. However I did turn the motor while watching the lifters and they all raise and lower.
The truck has 20k miles original, yes twenty thousand miles and the lifter looks new, slight convex no cupping or even wear marks visable, I watched the lobe thru the lifter port and it to is well oiled and looks good. Hell the valve train looks new.
Question is, can I fix the lifter? Thats if the plunger is stuck and not loaded, I am concerned that the lifter bars that are for manually lifting the lifter out of the port are gone...looks like the pushrod damaged them.
If no, can I replace all of the lifters with new, or must I replace the cam if I replace the lifters?
Thanks!
Thanks!
