lift issues
Marshel
Have recently purchased a 1966 Scout 800 and am looking to lift it but there are very few to non-existant. I have a busted tracker that has a body lift was wondering if the two are interchangeable? Any help will be welcomed.
I did extended shackles and an add-a-leaf on my 800B. I gained about 3". I'm getting ready to try the cj lift springs that has been done in the past.
Was thinking of heading that route aswell , but for now on a very limited budget. Also was thinking maybe a spring over tring to fit 35's at max under it right now have 33's stuffed in there but havent taking it out to see if im gonna run into any clearance issues
33's on a stock 800. Probably fine as long as you don't leave the pavement or go over any speed bumps. Otherwise you will rub for sure.
