Soft_Click
One of the first things I did on my 1966 1200A 304 pickup was change the water pump. I got one off Rock Auto (before I knew about IHPA) and also bought a gasket from them. Of course the water pump came with a gasket, so I used that one and tossed the other.
Immediately there was major leaking.
Like a steady drip. I didn’t manually turn the pump to prime it and I didn’t torque the bolts to a specific number. I just got them tight. The water pump looked a little different from the one I pulled off, but the mounting surface matched and the gasket looked like a good fit.
I recently drained the system, pulled it off and removed the gasket, which was some kind of paper and was a soggy mess. Cleaned both surfaces really well (which I didn’t do the first time), then made my own gasket with permatex Black gasket maker. It seemed to work for a little while, now it’s really dumping out again. I haven’t driven more than a quarter mile since I started working on this truck, just idling while tuning The carb.
I just bought a new gasket from IHPA and I want to make sure I do it right this time. Is there anything obvious I’m doing wrong? I’m reading online about some water pumps forming a mechanical seal by being turned by hand first?
Any advice is much appreciated!
