For what its worth, a '79 did come from the factory with a t-quad. It will pass smog. You'll need a catalytic (just one, no dual exhaust allowed), the air injection pump and tubes, the flapper in the exhaust, the heat riser hose from exhaust to air cleaner, the charcoal canister and egr bill mentioned, as well as all the necessary vacuum switches and hoses. Initial timing can be set at 5* btdc instead of 0 like earlier years.
The biggest thing that got me down here in la is the fuel tank pressure test. Not only do they test the seal on your gas cap, but the machine pressurizes the tank to test for vapor leaks. The truck could blow perfect numbers from the pipe, but if it fails the tank seal test, no deal. So all those vent lines going to the plastic vapor catch in the driver's side quarter panel have to be up to snuff.
Since you're somewhat removed from the big city, you might be able to go to a referee station and get the full story. Rural locations are less stringent as you know, so you might be able to get by with less than we can down here. A referee place will know for sure. The smog test places barely know what kind of truck you have, so they're usually no help.
A thermoquad was available as early as '74. Only the full size rigs came with holleys.
