kyleandhisIH
So it's thanksgiving. My oldest half-brother owned two Scout II's. One sold, one still sat in the yard. I liked it, it was a big vehicle inside.
So after dinner, when he leaves for st. Louis, he says "happy thanksgiving." and throws me an envelope.
Title and whatnot. A 1977 IH Scout II (or so I thought!), 304 with 3spd auto.
Here are pictures of it as it sat in my yard for several years. Lots of mowing around this one.
The top is obviously not factory, unless this is some expensive blue on black rock'n roll custom paintcanjob.
And I couldn't find pictures of another '77 sii with this grill...
Rough seats... Buckets, with console.
304, 2210c carb on top.
if ya cain't tell, I'm in mississippi river flatts here. Swampeast Missouri, all dried up and drained out.
It's not a recent build, but I figured I didn't have anything else posted here. Might as well show and tell a little.
If I shouldn't post this, I understand, since this is really a place for private projects and the outside info to supplement them.
Next:
This'n is a 1979 Scout II fershure. Bought it $200 for parting out. Now, I'm not so sure I don't want it self-movable...
fever is common in these vehicles.
It has a terrible body as you can see... Po (really just had it sitting) tells me he got it from some guys who pushed it out of a ditch with a d-9 dozer.
After getting under this thing, I find out it still has a tab to say 3.54 gearing, same set as the '77 model.
Brake pedal is free, haven't even looked into it. By now I've got the dash disassembled inside, we robbed the hard top seals, and the only valuable part is the tilt steering / drivetrain / axles / maybe frame.
It has a t-19 wide range, behind a 345 with ac setup. The clutch is sloppy, I stole the coil, the radiator won't do, but the po says he started it up a few years back, and it ran fine. Has a replacement starter I do believe.
Passenger-friendly seats (were later successfully robbed, put into '77 no trouble)
then begins the doing. Startup first time, no other work done:
First day, poured gas down carb. Apparently required good cleaner soak, which we couldn't give it. Ran for 30 seconds while Mom got a picture.
After removing radiator for recoring, just a good shot of semi-clean engine with no hood in the way.
Can anyone say soft-safari package? Maybe I'm wrong.
Having trouble fitting all the images into the first thread, more will follow of the work we did.
Next:
