Michael Mayben
It's been suggested by one of our members that we need a stickee regarding the subject of installing a distributor and verifying the spark plug cable locations. So here it is...this process will work with appropriate adjustments for both an sv engine and the 152/196 (I-4). I've extracted and edited the text from a very early thread that was posted to this sub-forum based upon an issue brought up by ihon member travis:
"align the timing Mark on the crank balancer (or hub depending upon the engine series) to tdc on the compression stroke for number eight (8) cylinder. As you come to tdc, stop rotating just before the timing Mark aligns, do not go past the Mark and then come back to it! Important! The most acccurate way of determining top dead center (tdc) is to remove the valve cover on the passenger side head and look at the rocker arm position for #8 cylinder (#1 cylinder on an I-4 engine). On the compression stroke, both rocker arms will be closed and kinda "loose" when ya move 'em.
Make certain that the oilite bronze bushing is in correct position in the block just above the oil pump drive, it must be there otherwise that distributor will not last more than 10 minutes once the engine cranks.
Then align the distributor rotor with #8 plug wire terminal on the cap and rotate the distributor about 1/8th of a turn counter-clockwise and then drop into position while ya wiggle the rotor to allow the gears to mesh, the oil pump drive tang will go into it's slot first and then the drive gear will slide into mesh with the cam gear. The rotor tip should now be pointing at the #8 cap terminal (or #1 if an I-4). It won't be perfect alignment until ya rotate the distributor a tad.
Next just snug the distributor hold-down in place to allow the distributor to be rotated by hand so you can set the timing.
Looking straight down onto the distributor, the distributor "direction of rotation" for these engines as installed in passenger vehicles is clockwise.
Next up, re-wire the distributor cap starting with #1 cap terminal which is the terminal just to the right of #8 sv application, looking down on the top of the cap). The firing order again is...1, 8, 4, 3, 6, 5, 7, 2. Firing order for the I-4 is 1, 3, 4, 2. So follow that pattern around the cap, plugging each wire into it's appropriate cap terminal and then the spark plug for that cylinder.
Once you have the distributor cap wired correctly, verify either dwell if the distributor uses breaker points, or the reluctor air gap if the distributor is either a Holley electronic or the prestolite electronic.
Once the engine is running and dwell is confirmed, then set the base ignition timing using your preferred method."
