sweet michael, that's exactly what I was looking for. We have a guy we call at the mooney factory that has a brain like yours. To bad we can't download minds like the internet. Thank you very much, Danny
Yeah...but the guy at the mooney operation,...if he tells ya the wrong thang, you will fall outta the sky!
Worst thang that I can cause is a "stuck" in the middle of the bay bridge or the golden gate at rush hour!!
Let me reinforce (not just for you!)...the dual throttle return springs we do in these kits are a major safety item! One goes inside the other so that if one of the hook ends should ever break off, the other is there for a backup. If adjusted right, that does not increase the effort required on the accelerator pedal. You just have to use your own judgement and abilities to make the good return spring setup!
That coil spring you see around the throttle shaft behind the throttle arm is not a "return spring". That is a liability kinda condom for Holley! For many years none of the aftermarket replacement carbs used that spring...then all of a sudden they showed up in "new" production.
The manufacturer (Holley) knows they have no control regarding "how" the end user installs this stuff. And many folks simply do not think about the return spring deal and think that just happens by magic! You cannot believe the kind of lashups we see on this old stuff where they have nothing but maybe a heavy rubber band rigged in place! So Holley started installing that "safety" spring as a last resort to close the throttle butterflies (hopefully).
When working with these Holley 1904 carbs on the old scouts and pickups, the oem throttle controls are major piles of crap when new, so I always rig something that is more "modern" for a positive throttle return directly on the carb. That also makes a huge difference in being able to set the correct curb idle speed and mixtures!
If you have any questions or need more help with making the install be sure to post up in this thread, customer feedback is the primary way we have of knowing that custom stuff like this works in the best manner possible! And many times, we know the customer is fighting po virus so they really are at a loss when "their stuff" doesn't seem to look/work like "our stuff"!!
