towpainter3
One other thing that sucks!!! On these motors is the intermittent oiling thruogh the cam. Correct me if im wrong, but after building my 304 and doing the priming process, with no v/c's on. I saw no oil on either of the rocker assemblies. After a very big session of cussin myself and my buddy at the machine shop, like that woud help, I thought roll the motor while priming and see what happens and to my surprise look jed its oil!!! Rolled it a little more and got both sides whew!!!. After further investigation and a long talk with one of the ol hands at the IH dealer.he explained the system and showed me the holes in a 345 block and cam and the intermittent oil feed. He said this sucks but it works. Unless your cam bearings are in wrong or have seized up and turned. And also , he said nuttin but wix or baldwin . I use the purolator filter myself cause its easy pickins here. Mine leak down after a day or so of sitting but the pressure goes to 50 at start and stays around 48 when hot. At idle , hot it drops to about 20 lbs with 20 50 ,touch the throttle and back to 48 or 50 lbs
