Scooter
Active member
Doh!! Bummer dude. Were ya trying to find a good fishing spot or what? As in an IH boat anchor - lol just kidding.
Sounds like ya sucked water into the cylinder and bent the rod while rotating into the compression stroke.
Depending how bad the wear damage is, your looken at boring out the cylinders, and 8 new over sized slugs. Basically a complete rebuild. Worse case senerio, if the wear is beyond the normal range of over size pistons then you're looken at a new block too.
