I have a 79 Scout II, and when I turn off the ignition, it kills the engine as it should, but does not kill power to the vehicles electronic systems.
It's a 79 Scout with a 345 v8 and a 4spd manual transmission. Everything is pretty much stock with the exception of dual battery set up with winch, bright lights kit, an additional painless 7 circuit fuseblock added to the factory electrical system that has fog lights and an extra outlet run off it.
As it is right now, I have to disconnect the battery so the battery doesn't drain as power is being fed to all the electrical systems in the vehicle even when the ignition switch is off. The locking cylinder seems to be activating the ignition switch as it should. I verified this by removing the ignition switch from the lower steering column and manually adjusting the switch through the acc, on, and start positions. I initially thought it was a faulty ignition switch and replaced it. However this did not correct the problem. Everything on the vehicle works fine except for the power not being turned off when the ignition switch is off.
This problem started occurring a couple days after I replaced the dash and the stock gauges. I've gone through the service manual to verify everything is wired as it should be. One more thing when I reconnect the battery while the ignition switch is in the off position, no power is being fed to the vehicle. It isn't until I turn the ignition switch to the on position and then back to the off position that problem persists. I'm at my wits end and figured it's about time I ask the experts. It's probably something dumb that I'm missing, but I'd appreciate any input that you guys can give.
Chris
Chris
