Got er running late last night. To solve the rocker/stand clearance issues I had to take the assy out and adjust some of stands. The hole in them is pretty big and there is room to adjust side to side and still get the bolt through. Also, I spun the engine over by hand to confirm that the loaded rockers had play when they were unloaded.
Before starting I verifyed oiling. I had very good flow at all rockers. One thing that I noticed was oil did flow slowly out from under the hollow oiling rocker on driver and passenger side. I loosened all the stands up and retorqued them, but it still happened. I guess the metal to metal interface of the stand and the head is not oil tight. The flow was very good up to rockers though, so I decided that it should not be a problem.
The valve train sounded really good and quiet. It seems to idle much stronger now and respond to throttle quicker. Also the exhaust note is much lower and stronger now. I didn't drive it much, just around the block to the other side of the street, no more parking tickets!
Is there any special driving mode I should follow to break the lifters into the cam?
