humidity
reitsma
Rust will kill the beast, so purily out of curiousity I was checking the humidity in my garage, it turns out to be a good 60% + (like a scandinavian sauna :p ).
Should I get worried or is this acceptable?
For much of north america, that's a relatively "low" "relative humidity" data point laurens! Typical summertime humidity readings in the afternoon, in the south central and south eastern u.s. Can be 70%>90% during seasonal micro-climates.
That's not what rots this stuff, it's accumulated road salt-type solutions used in much of the u.s. During winter conditions. And similar problems exist in coastal areas, particularly adjacent to the gulf of mexico. In parts of the u.s., folks can still drive inna limited fashion on the beach area adjacent to salt water and the really creates a problem...along with elevated relative humidity levels.
Have you been able to "power wash" the entire vehicle since you brought it home? If not, that would be something good to do, that way ya can attempt to flush all the accumulated road debris out of the crevices throughout. Scout II are terrible about trapping debris inside fenders and rockers. But then...based upon your pictures we've seen, you already know that!
Recording daily rh levels all across the u.s. (real time measurement taken with a electronic hygrometer, not from the weather service) was part of my former occupation. I had 12 years of accumulated data that was lost to posterity when my former employer was taken over by valeo (I know you are familiar with valeo!!!).
Ya May also be able to rig some sort of thermostatic-control electrical resistance heating unit in your shop/storage space, we do that here for keeping moisture levels inside of recreational vehicles under control.
Thanks for the wise words mr mayben, I have tried powerwashing the Scout before stowing but not good enough as it shows now :sosp:
I will give it a go with the steamcleaner before I start welding, there's still some mud and blubber hiding here and there I reckon...
Your weather station pic shows the same as my shop onna typical winter day until I turn the heat on. And my shop is in the house!
I can't show ya that with a pic...but out in shop right now, my hand-held digithermometer/hygrometer shows 47*f x 69% rh (unheated overnight). The big digi-unit on the wall got wasted when I accidentally "dropped" a camper shell on it I hang from the ceiling when not in use! At the same time, it kinda messed up my head too, but that was messed up before!
Humidity sucks, but dew point is really the one to watch imo. Ain't nuthin' worse than walkin' into my barn to see water dripping from my Scout! I try to run the heater out there when I know it's gonna happen but it's tough to keep tabs on.
If the area is small enough, you could run a de-humidifier.
-d
I haven't seen any condensation so far, the garage is about 300m3 I guess (not that big but very high), and well ventilated :gringrin:
I suppose I need a monstrous industrial de-humidifier to have some effect, so I will let it be...
