Simple brad, but many of ya have this same issue going on. Caused by the po virus and not knowing exactly what your setup is!
From your carb thread I gleaned you are running a breaker point distributor. No matter which distributor you have, delco, Holley, or prestolite, they all were originally wired with a "resistor wire" in the "run" circuit off the ignition switch. And all three systems used an oem coil with a primary resistance factor of 1.4>1.8ohms. That is important here!
Then, someone added a ballast resistor. Why?
If the original resistor wire is still in place, and then the ballast is stuck in there somehow, no tellin' what ya got going on..but that is why yore coil is takin' a dump as soon as it goes outta spec! Any coil would do that, it's not because of the oem mounting location, that idear is bogus!
If the existing coil has some statement printed on it that sez sumthin' like "internal resistor", then throw that sumbitch away, it's wrong for any application in the IH world!
Gitta coil with a primary resistance of 1.6>1.8 ohms, it'll say on the outside..."use with external resistor". Only...do not use a resistor if your oem resistor wire is still ok. Use one or the other reistive item, but not both!!!
The oem resistor wire is exactly 68">72" long and measures out at 1.8ohms nominal at 70*f.
A list of aftermarket coil part numbers is in one of the other threads here, posted a line item from my parts dbase with several typical numbers for greg r.
And there is a wide range of replacement "ballast resistors" on the market for many applications, including the chrysler dual circuit unit. You must check 'em with an ohmmeter at operating temp to determine the value. I keep 'em here in the shop in only 0.8ohm and 1.8 ohm values, the two commonly used in IH point/inductive ignitions (the 0.8 is used for the four bangers).
