Jeffsarasota
Afternoon everybody I've got a 78 Scout with a 345 v8 an automatic transmission. Two barrel Holley carburetor number 2210. Fresh professional rebuild.
Engine only runs well with a crazy amount of timing. Like 30° initial or 24° without the vacuum hooked up.
Even at this setting there is a bad mid range drivability problems with bogging ad hesitation.
I've looked at all the obvious things like a vacuum leak. I had the carburetor professionally rebuilt. I've checked top dead center on the compression cycle of number eight and everything checks out fine.
If I take out timing the bog and hesitation gets worse. If I add more timing it gets better.
It's a holly distributor with a prestolite cap. New wires new plugs new new rotor converted to per tronics electronics ignition
none of these things have helped it's still wants a lot of timing and I cannot get rid of the hesitation and bog.
I've done a compression test on the motor and everything seems fine. I've tried changing the distributor a tooth and it ran much worse so I'm thinking everything is stabbed correctly
so does anyone know how much mechanical advance I should get out of the distributor? Also how much is the vacuum can worth?
Runs absolutely perfect with no load on the engine. The mid range bog and hesitation only happens under load I.e. While driving the truck.
I'm wondering if a spring and bushing change on the dizzy would help? I have a musclecar background so I'm familiar with screwing with advance curves and changing stuff like that. I just need to know what the factory baseline and then maybe I can adjust from there. Thanks for all your help
maybe I set it up so it gets a shit load of timing real early in the rpm range. Right now with all this timing it's getting it's still not detonating or diesel when shut off. And it runs cold.
