Robert Kenney
Super Moderator
farmall57 I think my carb is closer to the 1710. If you look at the picture I posted, you will see that the bottom of the venturi is 1 1/2 inch wide. Which matches more with the 1710. I honestly believe that I have the 275 cfm model. I don't live above 7,000 feet. I live in the central valley of California. We do have most if not all gas stations in my home town that have gas with 10% ethanol. So is having the 60 jets ok or should I get a renew kit with the correct jets. Also I noticed that the metering block has a four digit number stamped into it. The number is 2325.
The .060 is big for a 304 and the 275 cfm mixer. It will be overly Rich and that can be bad on rings etc. If you are running a stock 304 and e10 you could run a .055 main jet and still not be lean..
Running the .052 mj on my 304 and it runs perfectly on pump fuels. More is not necessarily better.
