HELP! 1966 1200A 2WD Pickup - Wheel Hub Assembly
Jrambellows
I'm hoping someone can point me in the right direction. I'm not a mechanic, so please dumb down your responses.. lol.
My 1966 1200A (2WD) appears to have a drum/hub combo. Meaning you can't separate the drum from the hub housing, it's all one beautiful piece. My question is what other model year or make hub will fit on the stub axle (spindle)?
If you have an answer for the rear I would appreciate it since I'm going to have the same program with the drum/hub combo back there as well. I'm not doing anything crazy with this truck, so I'm not really wanting to rip out the rear end or front end for anything crazy unless I have no other option.
I'm hoping someone has found an easy answer to this or has even found a disc brake conversation kit that would solve this problem for me (providing it comes with a hub. I can't seem to find anything online that offers part compatibility for this car (for example a hub from a 1955 Ford F100 would fit, or work)
Answered your question in the other posting you made. Contact our parts department to put in an inquiry. 530-274-1795
I called and they don’t have a wheel hub or suggestion for this truck outside of swapping out the front end and rear end. I’m still open to suggestions on possible wheel hubs that could fit this truck.
