ReinBinder
Lets start with the specs: I have a 1970 800a with the 232 i6, 3sp trans 4wd. Binder ran great when I took it into our local IH dealership to have some seals and gaskets changed. While there, mechanic diagnosed fuel pump issues, installed electric fuel pump. He replaced seals and gaskets as requested. Now, as I drive the vehicle, it is losing power and stumbling under acceleration. Idles fine and fires up like normal. As I increase throttle it charges forward until about halfway through the throttle range, then no more go juice. I am assuming it is either timing or fuel. My thought is fuel filter clogged and only so much fuel getting to the system or something to do with the vacuum advanced timing on the distributor? I have a very limited knowledge of these machines and am not quite sure where to start. Any thoughts or pointers in the right direction?
