I have a 75 Scout II with a 345 v8. When started cold it turns over fine and fires up. After being driven for a while and engine is hot if I turn off and restart it struggles to turn over if at all. If left to cool it turns over and fires up. One time I went on a run turned the ignition off and it kept running wires began to smoke so I pulled off the hot lead at the battery. I left it to cool reconnected the battery and it started ok. I have replaced the starter twice and installed a heat shield around the solonoid. I had a mechanic do some work on it and he took off a fabric tube about 2 ft long that would fit around a pencil. I guess its insulation for a wire or metal tube.it has a silvery coating. Maybe this has something to do with it. The ignition switch occasionaly needs a key to turn it, other times not. I would like to put back the insulation tube even if its nothing to do with the problem but I dont know where it belongs. Im nervous to drive it incase it wont turn off and I cant get the hot terminal off the battery with the engine running.I also replaced the battery and the leads to the starter and ground. Should I put a shut off at the posative post of the battery. All advice welcome thanks.
