Took the 1975 Scout II out on new years day and did some wheelin in the snow. It did great. When I went to pull it out of 4x4 high back into 2x it popped pretty loud. Hubs were disengaged and I was in reverse.
It drove fine for bout 20 miles then I went to shift into 4th and it wouldnt go. I ended up having to stop and start in 2nd and it then went through all the gears. I drove it the next day and it did the same thing with the same fix.
I checked the tranny and t case fluid all looked good and I also put it back in 4 high and everything works fine. The only thing that looks slightly wrong fluid in the master cylinder looks low in the resevoir closest too the the firewall, its bout 3/8 full.
.... what would cause it to lock me out when shifting ?
quick specs ... 1975 Scout II 392 w/ t 19 4spd . Dana 44 axles w/ manual hubs according to guy I bought it from 12" clutch not sure how old.
