ronmc1954
On my 74 Scout II 345, d44s, front disk, rear drums: the problem is I seem to have little stopping power. It stops alright but I can't lock'm up, even on gravel. I put new shoes and brake springs and drums in the rear and manually adjusted for a slight drag. The front disks have not been touched but look good.
On gravel, I tried to lock them up and only the pass rear slid, a little, I can stand on the peddle so there is something there. On pavement I can stop but I can't lock them up.
The mc has never run low on fluid so air should not be an issue.
This prob seems to have occured after it has been sitting for a month getting a face lift.
The vboost apears to be working also, if I press the peddle the start the engine the peddle goes down and just the opposite when I shut it off.
Any ideas? I have read most of the posts here. It seems like something is sticking, wheel cylinder or proportioning valve?
Ron
Ron
