Not Scout related but could use the help. This site has always brought great advise.
Run of the mill Chevy 3/4 ton 4x with 350 vortec, auto, 140k. A friend bought the truck cheap because the truck wasn't running right(missing, no power, backfires).
He has replaced engine sensors, injectors, fuel filter, fuel pump. Also had the heads rebuilt. Pulled the cam out yesterday and all cam lobes are equal and look great, as do the roller lifters. Put the cam back in, and triple checked cam/crank in time. Adjust valves, replaced intake gasket ect... And the truck fired up with the same bad miss and backfire through intake, then stalled and will not fire. He has the snapon scanning tool to set timing, but couldn't keep it running long enough to set. Tried adv and retard the timing with no luck. Has even, strong compression on all cylinders.
Thoughts? Any help would be appreciated.
