Erik VanRenselaar
The 33" tires with 3.73 axle gears is fine for general-purpose driving with a 727 trans. My Scout II w/ 304 engine has that tire size/axle gearing, and it cruises quite well on the freeway. But I also modified the drivetrain by installing a low 1st/2nd gearset in the 727, and replaced the Dana 20 transfer case with a Dana 300 for a bit better 4l ratio.
4.09 or 4.27 axle gears would allow for better off-the-line performance, but then the engine rpm would be up there on the highway.
As others have suggested, work on the diagnostics and make sure the engine, transmission, and all the adjustments/specs of those are correct.
