mrscullini
on my '79 sII, 345, the po installed an electric pump. i'm not having any issues, just curious. i like the simplicity of a mechanical pump. what is the advantage (or disadvantage) of the electric pump over the mechanical?
One advantage of electric is if the vehicle has sat for a while it is likely to start quickly instead of needing a bunch of cranking to prime the mechanical pump and fill the carb.
Have a friend with an IH fire engine that he wanted to start right up when the key was turned. Installing an electric pump achieved this.
There is an upside to using an oem mechanical pump. All that cranking to prime the fuel system also primes the oil system too.
One caveat with electric pumps and carbed IH engines is fuel pressure. The mech pumps are calibrated to deliver between 5 & 7 psi. You want the same from an electric pump. This is easily achieved with a pressure regulator and verified with a pressure gauge.
Fuel overflow at the carb, flooding out and poor overall performance. You'd know that something wasn't right.
