Orange74
Ok so my issue is that the front drive shaft yoke on my d300 has about a +5* angle. This is causing my front drive shaft to bind at full droop. I used some 3/8 plate and made a spacer to go between the mount and the the drive assembly and this helped with the angle a little and before I go and make a bigger spacer I thought I would see if anyone has came across this issue or has a better idea.
