So......here goes. 1974 Scout II. Front pulled to the right, so here are the things I replaced trying to fix it. Replaced the booster and mc, replaced the prop valve, new pads all the way around and adjusted. Bench bled mc and adjusted booster rod (made it longer), bled entire system many times....brakes worked ok for a week, but still pull to the left when I brake hard. Today on a long drive, it started pulling hard in both directions (after braking). When I got home brakes were locked up and smokin hot !! After reading other posts, I released bleeder valve, fluid came out (small amount), but piston pressure was not relieved. I had to beat the calipers of with a hammer..
I am going to purchase new braided front lines in case of ballooning possibilites and new pads and calipers......I pray this is will fix my braking issues........please pass on some knowledge to !!!
thanks for the info!, I will post what happens.......so I got it all put back together (braided front brake lines and new calipers), when I bleed the brakes the front reservoir over flows!!! Aaaagh, as I pump the brakes the fluid acts as if it is transfering to the fluid to the other reservoir. Fluid is coming out at each tire too. What the heck is going on??? Please help.......need to get this thing back on the road asap cant find an answer in the manual
