Front axle replacement parts
burns189
Does anyone have the part numbers on hand for the axle bearings, inner and out seals, pinion bearing, pinion seal, tie rod ends, and ball joints for a Dana 44 front axle? Also is there a rebuild kit for the original IH locking hubs or is it better to replace with warn hubs? Thanks Matt.
I believe most if not every item mentioned can be purchased via the IHPA online store under the axle heading.
Click on the store button on the top of each and every page of this forum and you be able to get those part numbers, along with being able to purchase them too. IHPA just might have all your parts needs on the shelf ready to be shipped.
