Fixing Drunk Simulator
Yes that was on the way apart. If you look close to 12oclock on the drum there is a screw missing. If youre super observent, youl notice that on top of my floor jack is another bottle jack since the floor jack decided to bleed out randomly while i was removing a wheel. :mad2: Here is the front end now.
I always figure it’s better to state the obvious and hope it is not taken wrong than to not and risk an unsafe situation. I’m glad you were going to fix her up right. 👍
Yea. Lol in fact that was the whole reason why i removed the front end in the first place. There is still the consumable parts to replace, I have an old stabilizer that still seems ok Im going to put on, and im not sure if i should replace the tie rod, but its definatly bent. Then there is the pass spring bolt up. Im not sure but the flange on the axle for the front inside bolt looks screwed up.
