When I start my truck it runs fine. Then, in about 5 minutes it starts to blow white/blue smoke from exhaust. Pretty bad. All of my plugs are covered in oil, oil is clear, compression test read 125 psi in all cylinders except one read 150. Engine is a 304. I did have some valve taping and read that if you added an extra quart of oil it would help, so I did add an extra quart of oil and a couple of days later the smoking started. Oil level now back to normal but still smoking? Head gasket? Valve guides? Any clue? Thanks.
