71 Scout 2 was king enough to pm me the cam specs he recommended. Again, this isn't a cam grind that ihon has used but if anyone is willing to try it and return with some feedback that would be great.
"the cam specs I posted have a brand new (for 2008) lobe, so no I don't have dyno results. Like I mentioned before I don't have the time nor the resources to test every possible combination.
Here is was my suggestion:
intake
rated duration = 256
duration @ .050" = 212
lobe lift = .305"
valve lift w/ 1.6 = .488
exhaust
rated duration = 260
duration @ .050" =212
lobe lift = .296"
valve lift w/ 1.7 = ..503"
the "off the shelf" comp cams 83-201-4 specs as such.
Intake and exhaust are the same lobes
lobe lift = .293"
as you see they are really close. The profiles I recommended are just newer with quicker ramp rates.
intake
lobe lift = .305"
exhaust
lobe lift = .296"
lobe lift = .293"
