Hello,
recently purchased a '74 Scout II with 345, 727 auto trans, 4x4, originally from CA or hi. The diverter valve on the air pump is bad, and the general consensus is to junk the emissions stuff (not needed to pass a smog test in my state, nc). I am not an engine guy. I gather that involves removing the pump, injection manifolds, egr valve. I see a plate for blocking the egr valve port. What about the low temp(2) and high temp control valve(1)? Do they get removed or not? If not, do I just plug the vacuum ports or leave the vacuum lines functional? If so, how do you plug the ports? I guess I really don't know what these valves do, so don't know how to handle them. Thanks!
