They do know where their bread is buttered, that's for sure. I've got a bad habit of hasty reading sometimes. I initially glossed over your mention of this being a 2wd Scout. I don't know if that makes this swap notion any more or less practical. I now know that there are both 2wd and 4wd versions of the aw4 that came in xj's. So, on the one hand you wouldn't be dealing with a 4x4 t-case which simplifies matters. On the other, you'd still have to deal with an electronically controlled trans, some fab work for the mounting x-member, prop shaft mod/fab, plus shifter and associated linkage logistics. Then there's what I would assume to be a significant difference in curb weight between your Scout and a donor xj. Overall, I think your decision to not fix what isn't broken is definitely the way to go.
